Shaking
not sure if this is the problem but check your engine and tranny mounts. or a bad bearing somewhere. i bet its not those, but sometimes its the things you think of the least. when you checked your tires were they balenced properly?
Try to isolate the problem. When you reach shaking speed, put the transmission in neutral and let the engine idle down, andsee if things are still shaking. If the shaking stopped then it came from the engine. If shaking persists, it is coming from the chassis. If the steering wheel vibrates, check tire balance and alignment, check shocks, check for worn front end parts. If the vibration tickles your feet or butt check the drive shaft for bending, check U joints for wear, check rear suspension.
