serpentine question
Old Nov 15, 2006 | 06:48 PM
americanpower454's Avatar
Default serpentine question
I am looking to put a serpentine belt system on my car i have a v belt on there right now and going to take the brackets and tensioner off a 89 blazer. Can i use the power steering pump and alternator that i have on there right now and just change the pulleys or do i have to change it all? I don't have A/C or a air pump where would i purchase a delete kit for both of them? What kind of belt will i have to use?
Old Nov 15, 2006 | 07:10 PM
SickSickSick's Avatar
Default RE: serpentine question
Check This Out ... http://www.blackmountainprecision.com/sb6.htm ... Sick
Old Nov 15, 2006 | 10:25 PM
MadMikeZ28's Avatar
You should change it all at once. Keep in mind that you need to change the water pump since it is a reverse flow on the serpintine. The delet pullies you should be able to get from the dealer or I know summit has the a/c delete pully. And it should take the standard belt say for a 90 Camaro and with the delete I think it uses the same belt as with those accesorys.
Thats a nice cogged gear set but what do you do for power steering?
AzlebLyryc
Oct 31, 2011 11:07 PM
1971BB427
Jan 27, 2010 09:51 PM
GoofieJ21
Apr 13, 2009 11:03 PM
akohnz
May 9, 2006 10:11 PM
