runs fine when cold??
in my camaro 350 tpi it runs fine when cold but runs like a bag of **** and shuts of when it starts to get warm. leave it sit and it will run again then die when it starts to warm up. i unpluged the maf i was told that t his would bi pass it and its still the same. any suggestions? the cat was pluged and i just cut it out and put in a piece of pipe but i neevr hooked up the emisions pipe i just caped it off. its all unpluged on my car anyways but i dont think that would cause it because its all unhooked on my budies mustang and it runs fine. any help is greatly appreaciated.
aaron.
aaron.
the car is flooding realy bad, it throws out alot of black smoke. it will run ok for a couple mins if you hold the gas down but then floods out and dies and you have to haul the plugs out and crank her to get the gas out then it will start up again.. any ideas whats causing this.
dan1980davis
06-23-2013 10:36 AM
