running hottttt
85 z-28 305 HO carbureted it runs hot when the rpm's are up at idle it goes back down.
I have replaced the
radiator
hoses
cap
water pump
thermostat 195
head gaskets
had the heads magnafluxed no cracks
timing is right
eletric fan is hard wired on all the time
added a manual gage
please HELP ME
I have replaced the
radiator
hoses
cap
water pump
thermostat 195
head gaskets
timing is right
added a manual gage
please HELP ME
Hmmm sounds like an air flow problem to me, make sure all the parts to the air dam are there, there is the lip that hangs down and another peice that goes under the radiator and forms a kind of seal so that all the air is directed threw the radiator. Also try a 160* t-stat. Your fan is on the engine side of the radiator and set up as a puller right?
ORIGINAL: richardd
it gets hot in the driveway in about1 min. if i hold it at 2000rpm s
i just changed the 160 out also i live in hot AZ
