Removal of stock steering wheel from 89' RS Please Help!
Old 12-25-2005 | 10:13 PM
deswitzki's Avatar
Default Removal of stock steering wheel from 89' RS Please Help!
How do I get the steering wheel off? If removed the horn cap and unscrewed the nut in the center. All I want to do is replace my old steering wheel with a new grant challenger wheel. Please any help would be gretly appreciated.
Old 12-26-2005 | 01:15 AM
Boost's Avatar
Default RE: Removal of stock steering wheel from 89' RS Please Help!
You need to get a Steering Wheel Puller. Im sure that any major Autoparts store has a loaner tool program. I just used that carefully and it came off.
Old 12-26-2005 | 02:17 AM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
harmonic balancer puller also works if you can line the holes up right.....if not, they only cost like 8 dollars at most parts stores.
Old 12-26-2005 | 08:17 PM
HaloNick's Avatar
What do you do if it has the airbag? We want to get rid of ours and get a smaller and lighter steering wheel.
Old 12-26-2005 | 10:15 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
i would not suggest removing the air bag....
Old 12-27-2005 | 07:04 AM
JAK's Avatar
JAK
If you are unable to find a steering wheel puller you can usually make one with some spare bolts and some steel strapping.
As far as removing the air bag that is not a good idea for two reasons:
1.) It's illegal.
2.) It is a pain in the *** and could lead to injury.
If you still decide to remove it, I suggest disconnecting the battery before you begin. Best of luck!
-JAK
Old 12-28-2005 | 11:53 AM
deswitzki's Avatar
Thanks all ur post helped me, I did get the wheel off. Also their is no airbag. Only 1 last question. I unscrewed my turnsignal lever so before I knew how to get the wheel off, now I have to remove the lock plate so I can get back there to replace the screw. Should I use a steering wheel lock plate remover or compressor or does it even matter which?
libertyforall1776
04-11-2010 09:39 AM
jason7504
11-14-2009 12:41 PM
Slick6
11-15-2007 12:18 AM
rnhwizard
05-21-2007 06:36 PM
homes322
04-24-2007 10:15 PM
Quick Reply: Removal of stock steering wheel from 89' RS Please Help!
