Rear Drum brake bleeding issue
Old Aug 22, 2017 | 03:35 PM
B_Dubya's Avatar
Default Rear Drum brake bleeding issue
1990 camaro tbi
rs
The bleeder valves to the rear drum brakes are screwed in all the way and theres no room to get a wrench on it.
It looks like only a socket willl turn it out, but if i do that... how do i bleed it?
Do i just loosen it up with a socket and then quickly put the tube over it to make it drain into the pan?
The front brakes look easy, but these drum brake valves are screwed in so far, theres no way to get a wrench on it.
Old Aug 30, 2017 | 07:43 PM
B_Dubya's Avatar
Alright I figured out how to access the bleeder valves, however after doing the bleeding to all 4 brakes, it was strong, then i started my engine and bam it all went back.
I think it's because I did not bleed the Master Cylinder.
So now that I have to do this procedure again, I would like some recommendation
Should I take the bleeder valves out and let it sit over night??
Is that how you gravity bleed them??
Also,
Am I able to pull my master cylinder off and bench bleed it,
will I then still have to bleed all 4 valves again after I install the master cylinder?
Old Sep 1, 2017 | 11:19 AM
Everett#2390's Avatar
Yes, remove MC and bench bleed.
Yes, rebleed the system starting with the longest line first.
One can make a plate for the reservoir and with a fitting can put a hand vacuum pump on the fitting/plate and put a vacuum on reservoir.
This will create a low pressure on reservoir and any air in lines/cylinders is at a higher pressure.
Physics involved as high pressure volume will try to equalize the lower pressure volume.
Making plate from 1/4 inch Plexiglass will allow you to see bubbles emerge while vacuum is applied.
Old Sep 8, 2017 | 09:39 AM
Copesis1's Avatar
Get a bleeder vacuum kit and bleed from the farthest away bleeder first. Make sure you dont run the master cylinder dry.
If you dont want to spend the 20 bucks most parts stores will loan you it for free.
BobsCamaro
Aug 29, 2016 01:18 PM
Sante
Aug 24, 2010 07:03 PM
chopshop9
Jul 24, 2010 09:08 PM
ToledoG90
Nov 18, 2008 12:36 PM
libertyforall1776
Nov 10, 2007 03:04 PM
