rear disc brakes on 1986 carmaro
Old Oct 29, 2013 | 08:36 PM
flashgordon's Avatar
Default rear disc brakes on 1986 carmaro
i have been going round and round with summit on my rear disc brakes.i order ebc pads,after several sets,they did not fit ,i gave up.the pads i am using are bendix titanium metallic 2 mkd154. i order slotted zinc plated rotors,ssbc.they sad these fit 85 to 89,not my car.my rotors outside diameter is 10 1/2 " ,ssbc is 11 11/16. do i have the right rear? i have tpi and auto trans. is there some place place that make slotted rotors for this rear, not drilled? i would like to know before i call summit back. any information on this rear will help.
Old Oct 30, 2013 | 10:56 AM
the polisher's Avatar
Look up spec's on the G92 rear end, it should tell you everything you need. If I remember correctly the 10.5 were on 305 RS and the 11 11/16 were on the 350 Z28 IROC.
Old Oct 30, 2013 | 11:48 AM
Welcome to Camaro Forums. Moved your thread to the correct (3rd gen) section.
stewie
Feb 27, 2015 09:03 AM
sm515
Aug 13, 2010 04:24 PM
libertyforall1776
Nov 10, 2007 03:04 PM
mcnair
Apr 30, 2007 06:42 PM
camaro maniac
Dec 10, 2006 09:33 PM
