Quick question
Old May 1, 2007 | 01:50 AM
Goodfella's Avatar
Default Quick question
If the car was origionally a 305 but swapped to a 350 and still has the stock fuel pump, but bigger injectors, would it be a good idea to get a bigger fuel pump? thank you
Old May 1, 2007 | 03:23 AM
MadMikeZ28's Avatar
Default RE: Quick question
The 305 pump will work with the 350 injectors.
Old May 1, 2007 | 10:39 AM
blackz87's Avatar
The fuel pump is ok.But was a 350 chip installed in the ECM???
Old May 1, 2007 | 07:14 PM
Goodfella's Avatar
thanks and yes, i put a new chipin btw..
Old May 1, 2007 | 08:53 PM
MadMikeZ28's Avatar
Ok this was suposed to be a quick question so I gave a quick answer.
But when doing the swap many forget to change the knock sensor and ESC. Did you change those?
Old May 2, 2007 | 03:00 AM
uradumass5695's Avatar
carburate the car, engine mounted fuel pump, fuel injection sucks anyway...
(quick anwer)
but yes fuel pump will be ok
blackbeauty1995
Mar 18, 2014 06:08 PM
gmman200
Mar 1, 2009 11:36 PM
sk8erdude36
Dec 12, 2008 06:48 AM
Celticsfan
Oct 9, 2006 02:01 AM
