PLEEEEAAAASSSE HEEELLLPPP!!!!!!
Old Feb 26, 2006 | 08:34 PM
metalhead23's Avatar
Default PLEEEEAAAASSSE HEEELLLPPP!!!!!!
I HAVE AN 89 V8 CAMARO I AM TRYING TO FIGURE OUT WHAT THE PEICE IS CALLED THAT GOES FROM THE EXHAUST MANIFOLD INTO THE BOTTOM OF THE AIR CLEANER ASSEMBLY???????? I HAVE CONTACTED AUTO STORES AND THEY TELL ME I HAVE NO IDEA WHAT YOU ARE TALKING ABOUT???????? I KNOW ITS A HOSE OR PIPE BUT DO NOT KNOW WHAT IT IS CALLED ANY INFO WILL BE GREATLY APPRECIATED.
DEREK
Old Feb 26, 2006 | 09:15 PM
WayFast84's Avatar
Default RE: PLEEEEAAAASSSE HEEELLLPPP!!!!!!
AIR?
Old Feb 26, 2006 | 11:27 PM
That is probably the hose (heat riser) used to feed hot air to the engine during warm up. The air flows inside of a shroud wrapped around the exhaust manifold and gets heated up. There is a valve in the air cleaner that select hot or cold air depending on what the engine needs. Sometimes it gets stuck on hot and you loose a lot of power.
Old Feb 27, 2006 | 01:06 AM
vortec350s10's Avatar
yep- most people call it a heat riser pipe
Old Feb 27, 2006 | 12:11 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
yep. heat riser. about 5 bucks anywhere
