please help!!!!!
Old Jan 25, 2006 | 06:08 PM
Dickie90120's Avatar
Default please help!!!!!
hey i got a 89rs wit a 2.8v6 in it and for some reason the fuel pump is not shutting off when car is off. i believe it may be the relay but not sure. if u think it is do u know where the relay is located? also if u have any other suggestions to what may cause the fuel pump not to shut off ur help would be greatly apprieciated.[IMG][/IMG]
Old Jan 25, 2006 | 07:08 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: please help!!!!!
check the pump following the FAQ pinned
Old Jan 25, 2006 | 09:31 PM
hey thanks. it ended up being the oil pressure switch. for everyone else wit the problem there is a fuse next to ur batter, pull that if the sound stops then put the fuse back in, undo the oil pressure switch which is located right above the oil filter and it should stop. which means u have a defected oil presure switch or its being shorted out.
