plan to fix 87 iroc's bent frame
Old Feb 25, 2006 | 11:36 AM
hollopointclown's Avatar
Default plan to fix 87 iroc's bent frame
hello everyone,
I have a theory about fixing my iroc's bent frame. Every thing behind the front of the engine is fine. the arms that hold the bumper reinforcment are crushed back an passenger sides bent down 1inch an driver side up 1inch.
The plan: If i was to get a jack,big sledge hamer,chains, a welder an sheets of tin. An some how forced the frame level an welded the tin real nice to cover where the frame had been bent.
than thiers no reason why it wouldnt pass nh inspection, if its not visibly bent they cant tell, right. i havent figured all the details out but thats why i posted it on here to get some advice. thank you everyone[sm=jawdrop.gif]
Old Feb 25, 2006 | 05:01 PM
Default RE: plan to fix 87 iroc's bent frame
Have you tried a good body shop? They have the tools to straighten cars out properly. If just the front sub frame (engine cradle) is bent, you can get a good one from a scrap yard and replace your bent up one, just 4 big bolts holding them in place. Much better results than trying to straigten the old one. Just some ideas.
DarkFox
Mar 8, 2011 07:34 PM
1989fbody
Jun 29, 2009 05:28 PM
meteoralp45
Aug 20, 2007 12:58 PM
hollopointclown
May 14, 2006 12:46 PM
hollopointclown
Apr 7, 2006 07:16 PM
