bent camaro frame [ with pictures]
Old Jun 28, 2009 | 07:43 PM
1989fbody's Avatar
Default bent camaro frame [ with pictures]
i need help please i just bought a 1995 z28 camaro done a car fax and it said it hadnt been wrecked so i put it on stands and found that were the frame bolts to the impat bar was bent is this a major problem or easy fix
thanks
<div style="width:480px;text-align:right;"><embed width="480" height="360" src="http://static.photobucket.com/flash/rss_slideshow.swf?rssFeed=http%3A%2F%2Ffeed1008.ph otobucket.com%2Falbums%2Faf207%2F19956speed%2Ffeed .rss" type="application/x-shockwave-flash" wmode="transparent" /><a href="http://photobucket.com/redirect/album?showShareLB=1" target="_blank"><img src="http://pic.photobucket.com/share/icons/embed/btn_geturs.gif" style="border:none;" /></a><a href="http://s1008.photobucket.com/albums/af207/19956speed/" target="_blank"><img src="http://pic.photobucket.com/share/icons/embed/btn_viewall.gif" style="border:none;" /></a></div>
Old Jun 28, 2009 | 07:47 PM
1989fbody's Avatar
Old Jun 28, 2009 | 07:48 PM
1989fbody's Avatar
Default camaro frame
this is were u can see camaro photos and the bent frame pictures
Old Jun 28, 2009 | 09:19 PM
There is no frame on this car, except for the front subframe, that carries the engine and part of the front suspension. The impact bar is bolted to reinforcments on the unibody. If the bolts are bent, it is a good indication that the unibody has been bent also. At this point a straight impact bar may not fit. If the damage is not noticeable, it is probably best to leave things alone.
Old Jun 29, 2009 | 09:37 AM
1989fbody's Avatar
the bolt isnt bent the metal is just bent , if you look at the pictures you can tell what im talking about
Old Jun 29, 2009 | 10:46 AM
torque_is_good's Avatar
is the car in alignment?
Did you get a good deal?
it looks like you have a leaky seal there too by the photos
Old Jun 29, 2009 | 11:15 AM
Get a alignment. If they come back and say it can't be aligned you will need to get it fixed. If not all is good. These car are not perfect even new. A small teak like i see in the pictures is nothing. There is more variation in manufacturing then i see there.
Old Jun 29, 2009 | 11:33 AM
1989fbody's Avatar
i paid 4000 for car
it drives real good
handles good to
Old Jun 29, 2009 | 04:11 PM
I looked at your pictures, and see nothing out of the ordinary, except you have nut missing which ties the subframe to the body.
Old Jun 29, 2009 | 05:28 PM
cbr600rx7's Avatar
If its driving good and not wearing the tires or any thing crazy i would leave it be.
DarkFox
Mar 8, 2011 07:34 PM
69camaro400
Dec 25, 2006 01:22 AM
hollopointclown
Apr 7, 2006 07:16 PM
hollopointclown
Feb 25, 2006 05:01 PM
