Overheating issues
Old Dec 30, 2006 | 11:11 PM
kg4ekd's Avatar
Default Overheating issues
Ok, here goes. I know somebody that took a 305 from a92Camaro and put into his 89. I was told it should be the same engine, but I am not that familiar with those year models. Anyway, they rebuilt the engine before putting it in, and have had some serious heating problems. They have changed the thermostat, replaced the intake gaskets (which were installed incorrectly at first), the water pump (which they got one for the 92 and made sure it was for a serpentine setup), and have even straight wired the fan to run constantly. The only thing I can think of to try would be a new radiator. I had something in mind like a Be Cool aluminum deal with extra flues, larger tanks, etc. He is thinking about changing thewhole damn engine, but I think thatit would be sort of needless. Any help would be great. Thanks
Old Dec 31, 2006 | 12:19 AM
ghotachevy's Avatar
Default RE: Overheating issues
air bubble in motor water passage blocked with sealer/?
Old Dec 31, 2006 | 12:23 AM
MadMikeZ28's Avatar
How hot do you think hot is? Is the serpintine belt installed correctly?
Old Dec 31, 2006 | 03:58 PM
kg4ekd's Avatar
Well, from what I was told, when the car is going around 35- 40 mph, it does not overheat. But when it is idling it does. I don't think it is pulling enough air, but I am welcome to any and all suggestions.
Old Dec 31, 2006 | 06:10 PM
ghotachevy's Avatar
is there a fan shroud in place
Old Dec 31, 2006 | 07:45 PM
MadMikeZ28's Avatar
Is there crap plugging the fins of the radiator or condensor. Like leaves or dead birds.
Old Dec 31, 2006 | 08:24 PM
ghotachevy's Avatar
hate them dead birds in the radiator
Old Dec 31, 2006 | 09:27 PM
mongo's Avatar
could be that the cpu is not responding to the newer motor or the wiring to the motor itself is done wrong
LeeJohnson
Jun 5, 2014 08:38 AM
Bjm3.8
Mar 29, 2012 11:07 PM
Bjm3.8
Sep 24, 2010 01:12 AM
nelly_2132008
Sep 1, 2009 12:46 PM
nelly_2132008
Sep 1, 2009 08:57 AM
