Oli leak after replacing distributor
Old May 30, 2009 | 11:07 AM
smoothjazz's Avatar
Default Oli leak after replacing distributor
Hopefully someone can help.I recently replaced my stock intake and carb.Reinstalled everything on my 305.Tried to start,but nothing.Double checked to make sure everything was hooked up correctly,and found a oil leak coming from bottom of car.Can anyone tell what may have happened? Did I totally mess something up?
Smoothjazz
caravansari@hotmail.com
Old May 30, 2009 | 11:23 AM
what yr and model? if the car did not start then oil would not come from certain places in such a short time. i would say something did not get changed or is not hooked up or was damaged during intake change. oil pressure line something like that. follow the oil trail and see were it leads. did u install the dist. right and get the wires right. its common to get the dist. in 180 degrees off. also common to get it a tooth or two off but can usually turn the dist to correct.
Old May 30, 2009 | 11:35 AM
Did you put a gasket between the distributor and manifold? You need to look and see where the oil is coming from. What did you use to seal the end valleys between the manifold and block? I hope you didn't use the (sometimes) supplied rubber ones. Those have a tendency of squishing out if the fit isn't near perfect, and causing a big leak. RTV ONLY on the ends!
Old May 30, 2009 | 01:05 PM
350rs's Avatar
March 2008 ROTM
agree 100%. If you used those rubber do dads take them out and just lay a THICK bead of RTV. Check the gasket below the distributor. Valve cover gaskets. Any number of things
87Bob
Jan 28, 2012 07:58 AM
t-fly
Jun 26, 2009 07:52 PM
raleigh23
82-92 V6 Tech
Apr 19, 2008 01:43 AM
6v49der
Sep 7, 2007 02:38 PM
akohnz
Apr 10, 2006 07:08 PM
