oil pump/pressure
Old 03-29-2007 | 01:53 AM
MadMikeZ28's Avatar
Default RE: oil pump/pressure
No there is no reason for a high volume pump for street use. The satndard volume can have half the oil capacity at the top of the engine. But a high volume does not double that. I was surprised to see that the factory put a high volume pump in my 4.3. But I have seen many times big blocks low 3-4 quarts low( some times more!) And a big block pump is a high volume pump. No failure in any of them. (maybe some failure in the ones really low)
I have also seen problems when priming. Using a drill to weak to turn the pump. A pmp with a standard pressure spring takes a lot to turn. Or priming with the filter on. That traps air and wont prime well.
And a windege tray helps also
jim64123
04-10-2013 08:31 PM
rachel11
02-27-2012 02:53 PM
Bjamz
09-14-2011 08:39 PM
walker61
06-07-2011 01:47 AM
AlaJoe
02-18-2011 08:56 AM
Quick Reply: oil pump/pressure
