How much pressure on a fuel pump?
Old Apr 10, 2013 | 03:53 PM
jim64123's Avatar
Default How much pressure on a fuel pump?
I currently running a 650 holleycarbureted 350 with an electric pump. How much psi should it be pushing? I'm wondering if its set to high right now and that's part of why it smells like its running rich.
Old Apr 10, 2013 | 08:31 PM
Everett#2390's Avatar
Holley 12-801 pump, no regulator suplied and does not need one, generally about 5-7 PSI.
Holley 12-802 comes with a regulator and generally set for 6 PSI.
If running rich, look down the air horn and if fuel is dribbling from the venturis, then float level set too high.
Also, you might add alittle more initial timing and reduce throttle opening and readjust mixture screws using a vacuum gauge on full manifold vacuum and adjust each mixture screw for highest vacuum reading.
mitchman
Jun 10, 2013 04:45 PM
rachel11
Feb 27, 2012 02:53 PM
Bjamz
Sep 14, 2011 08:39 PM
walker61
Jun 7, 2011 01:47 AM
AlaJoe
Feb 18, 2011 08:56 AM
