OEm replacement mouldings?
Old Dec 24, 2007 | 02:00 PM
Coveted Hilton's Avatar
Default OEm replacement mouldings?
for an 82 camaro, i really want to shave them, but some OEM mouldings would be nice.
Also (dont slay me please)
has anyone done a roof swap, or any ideas, i kinda want to get rid of my t tops.
im going with a cage anyways, or im wondering can i go less then 10 seconds with t tops.
some tracks are weird about that stuff.
Old Dec 24, 2007 | 03:38 PM
MadMikeZ28's Avatar
Default RE: OEm replacement mouldings?
OEM mouldings the best place to look would be the junk yards, Craigslist.org, ****-e-bay or if new is needed and the money burning a hole in your pocket places like nextgenparts.com or classicindustries.com.
As for the roof replacment I have had to do it on wrecks before. None were Camaros. You could fake one on there easy with the skin and a portion of the framing or all the way down from the bottom of the window post. But you may want to see what the track allows. The local spped shop used to sell the regulation hand books. Though the local track did not follow them for the wednesday night high school drags.
Also you will have to find out what is required of a cage. There are rules to follow on them also. Some times they are real strict and want it tested and made of a certain size tube.
Old Dec 24, 2007 | 05:10 PM
i was going to save the hassle and order a jegs nhra approved cage.
i guess shaving the mouldings would be best then thanks for the fast reply
Old Dec 24, 2007 | 11:40 PM
Arizona Camaro's Avatar
If you go with the Jegs cage you will have an easier time installing it with the roof removedso you might as well cut the Ts off and install the hardtop afterwards.
Too bad your so far away you could cut off one of mine [8D]
9434V6
Jun 9, 2013 11:46 AM
southw2
67-69 V8 Tech
Jun 12, 2011 10:09 AM
southw2
Jun 4, 2011 10:23 AM
hammsman
May 21, 2011 11:43 PM
hammsman
Apr 15, 2011 04:39 PM
