no power with swapped in 305
I just finished swapping in a 305 into my 92. old motor was crap. anyways to motor is in now and it runs... had to mess with the timming a bit to get it started but now that it is running.. it feels like it has no power. there are 2 more connector that I need to hook up that go to the tranny but i dont think they have anything to do with this. so car runs with very little power, takes a few seconds to start... any ideas where to start. Im thinking its a timing issue but any recommendations are welcomed.
p.s. I just found out I need to replace the water pump and alternator
thnx in advance
thnx in advance
today I hooked up correctly the diverter valve lines and the water lines. also I had missed the air line to the cat. I did notice that I need a new water pump. Maybe that had a part.
I have 2 plugs left off the harness to find a home for.. there are right by the fire wall on the passenger side... I think they are off the tranny..does that make sense ?
this was supposed to be a car I like and could get around in with out a car payment.. but its taking more of an effort than i thought. I have a buddy at a shop look at it on thur to set the timming..I hope it helps. Im starting to miss my 98 z28
