no power
Old Sep 10, 2005 | 09:49 PM
blkcamaro's Avatar
Default no power
i have an 85 camaro berlinetta with a 305. I just put another 305 into it. the old one had a cracked block because the it was left out in the cold and it froze before i got the car. Since we have swapped motors the car has no power. when you push the gas the rpm's drop for a few seconds and then they start climbing again. there is no load on the car because it happens in park. the car has been setting for quite a while with a full tank of gas. could this be a problem?
Old Sep 11, 2005 | 01:26 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: no power
yup. you need to get all that old fuel out and change your filter
Old Sep 14, 2005 | 05:27 PM
blkcamaro's Avatar
Well would taking off all of the egr be a problem because i eliminated the smog pump and i took all of the egr tubes off of the exhaust manifolds and plugged them w/ some bolts.Also i forgot to mention on the first post about the car running extremely rich. i just replaced the 02 sensor so i dont know whats going on there. any ideas?
MaxTheKiing
Aug 23, 2010 03:21 AM
rbeard
82-92 V8 Tech
Aug 9, 2009 12:11 AM
dkblind87
LS Series Tech
Jul 27, 2009 05:35 PM
IBADRIDE
Jul 13, 2006 01:44 AM
