no fuel need help
Old May 27, 2005 | 11:24 AM
hartattack's Avatar
Default no fuel need help
i have a 84 camaro with a 305 engine manuel tranny. i am a novice mechanic who needs help. my camaro turns over, the fuel pump is working, the fuel filter was clogged so i put in a new one, the car is still sarved for fuel. if i spray starting fluid into the carb is fires right up, then of course stops running. i need advice where to go next, and what steps to take to fix this prob. summer is coming and i'm bummed out. thanks in advance.
joel
Old May 27, 2005 | 12:19 PM
Patrick's Avatar
Administrator
Default RE: no fuel need help
is it carbed? i know that my 83 was, so if you remove the air cleaner, with the car not running, watch and see how the fuel looks going in..perhaps you have a carb problem. that way, you will also know if the fuel is getting to the carb
Old May 27, 2005 | 04:31 PM
hartattack's Avatar
its a 4 barrell carb , the carb is not getting fuel to it. its getting fuel all the way into the fuel filter area but thats it. the org fuel filter was blocked thats why i changed it out. its pumping fuel fine up to that point but the carb isnt getting fuel. thats why i stated it willl start with starting fluid, its starved for gas.
Old May 27, 2005 | 08:49 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
timing
Old May 28, 2005 | 09:46 AM
hartattack's Avatar
has nothing to do with timing, the fuel isnt getting from the fuel filter area into the carb. the car runs fine witha continous spraying of statrting fluid. i have to figure out way the gas stops at the filter, whats blocks or no good from that point on.
thanks
Old May 31, 2005 | 11:40 AM
runedawg's Avatar
Is it a stock replacement fuel filter or an aftermarket replacement? Did you put the fuel filter in backwards? Some will not flow if reversed.
Old May 31, 2005 | 04:34 PM
Patrick's Avatar
Administrator
correct..check the direction of the filter, and then start checking points between the carb and filter to find your issue.
Kendagenius
Feb 5, 2017 12:23 PM
mrfreez
Jan 21, 2011 11:58 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
