No Fuel!!` Need Help Asap!
Okay here is what i got. I recently purchased a 1992 Camaro Rs, it has the V8 305. The car was running good until today. I pulled the car into my backyard to do some body work, and when i wanted to pull the car back up front it would not start. I first thought Fuel Pump so i tested it and it works good. Next my buddy said probably a relay or a fuse. so i check the relay and replaced it, still no good. then i looked for the fuse, couldnt find it, where would this be, Fuse box or in engine compartment. What else could it be? when i hook 12 volts to the pump it works, so obvisioly it got no power.
Any help will be greatly appricated.
p.s. sorry for spelling.
RE: No Fuel!!` Need Help Asap!
There's an inline fuse right behind the battery that should be either attached to or nearby the passenger side fender. It's inside of a small black casing with two wires coming out on either side.
is that what that little ****ten thing is?? mine is attached to the fender. i noticed that awhile ago, pulled off the boot and there was a small fuse in there. Well then, thats one mystery solved. Thats an odd place for that.
johnson3034
05-25-2007 09:35 PM
