Nitrous
Old Apr 21, 2005 | 01:23 AM
CAMAROcruiserFL's Avatar
Default Nitrous
Im putting nitrous in my camaro in the next couple of weeks. What would the safest shot be?
So i dont blow my engine.
Old Apr 21, 2005 | 06:18 PM
Patrick's Avatar
Administrator
Default RE: Nitrous
engine? year? mileage??
technically NO nitrous is safe...i have seen guys run up to a 100 shot on a stock engine, but that was on a newer engine, and it eventually did fry the rings...if youre going to run any heavy shot..make you sure that you hook everything up exactly right..no shortcuts! and make sure its a wetshot system!!
Old Apr 21, 2005 | 06:47 PM
Default RE: Nitrous
Why make sure its a wet shot? Can i do a wet shot to a carb engine?
Old Apr 21, 2005 | 06:50 PM
Default RE: Nitrous
oh yeah the engine is an 89 we rebuilt it and made it carb there is about 500miles on the engine now
Old Apr 22, 2005 | 03:19 PM
Patrick's Avatar
Administrator
Default RE: Nitrous
is it completely rebuilt? one rule of nitrous...IT WILL FIND THE WEAK POINT. make sure it is wet shot because it lowers the chances of running too lean. you can make anything wet shot...but once you install it, make sure that you have a fuel presure gauge because when fuel pressure dips too low, you WILL blow the engine...you want to make sure that youre running a bit fat at lower rpms, and when the juice gets in, it will automatically lean out.
to safely run nitrous you will need to make some sort of throttle position sensor..you can, in theory, set it anywhere, but you only want the nos to inject at full throttle...
if you need help, i have a fair deal of knowledge about the setup of the systems, for either carb or FI
noer
Sep 18, 2009 05:08 PM
rockin85
Sep 12, 2007 10:10 AM
Eric89RS
Aug 31, 2007 11:48 AM
likearock91288
Aug 13, 2007 09:18 PM
traXion
Jun 16, 2007 11:38 PM
