Need Tunnel Ram Info
Old Apr 25, 2006 | 11:00 PM
SickSickSick's Avatar
Default Need Tunnel Ram Info
I'm looking At A Tunnel Ram For My Iroc. The Ram Has No Center Ports To Match Those On My Heads. It Says It's For A Small Block Chevy Tho. Whats The Deal? How Does It Work Without Using The Center Ports On The Heads? Sick
Old Apr 26, 2006 | 01:38 AM
Default RE: Need Tunnel Ram Info
There is no center intake port on small block Chevy heads. The center passage is for exhaust gas circulation to heat up the intake manifold for better cold weather operation. You do not need this passage on performance engines, as you do not want any extra heat in the intake.
Old Apr 26, 2006 | 02:58 PM
Thanks Pete. Sick
Wayne G
Nov 15, 2013 08:11 PM
78 on my plate
Dec 2, 2012 04:14 PM
chernmax
Oct 10, 2012 02:13 PM
Bad_Z28
Mar 12, 2011 07:19 PM
littleredcar
Oct 13, 2007 10:56 PM
