Need some help i think its the exhaust but where?
Old Jul 3, 2011 | 05:55 PM
Stevolwevol's Avatar
Originally Posted by Joshua85
okay after trying everybody's tips and ideas to know avail. the car runs a little better and the sound came back. when i took the car to the shop they said they couldnt find anything wrong with the exhaust but they said it may have something to do with the overheating which they followed with i should put the right fans in. which brings me to my next problem i bought darle dual 12 inch high output fans rated at 3000 cfm a fan. They work amazing but they are 40/60 amp fans and i am having a problem finding a alternator to run the fans and the a/c so if anybody can help with that or have ideas that would be great and i hope that this will solve my exhaust problem to if there are linked. i did the math and i need a alternator with a minimum of 160 amps and a single wire setup. thanks to all those that helped me diag the exhaust
I am curious as to where your sound went, and how it came back. Something is still wrong if you need an after market fan to keep it from overheating.
I did some reading after reading this thread, and discovered that deposits accumulated in the water jackets in your engine may be the cause of mysterious overheating. Maybe a complete flushing could be the answer.
Old Jul 4, 2011 | 08:37 PM
microkid's Avatar
March 2011 ROTM
Technical User
i am running a 4000 cfm derale set up with the stock 105 amp alternator. it is a bit of a draw at idle with the lights on, but my idle is low. you shouldnt have any issues with a 140 amp alternator, just dont sit a red light in reverse with the high beams on with the a/c cranked while the radio is full blast and putting the windows up and down while the four ways are on with the door open...
Old Jul 10, 2011 | 10:18 AM
Mrjshua's Avatar
Good call
Old Jul 10, 2011 | 10:54 AM
Originally Posted by Mrjshua
Good call
Huh?
scottlt194
May 14, 2009 08:27 PM
famlyguy18
May 6, 2009 05:26 PM
dbess23
Sep 17, 2007 02:02 AM
javione
Feb 16, 2007 02:27 AM
jhop16
Jan 9, 2007 11:21 AM
