Need some advice!
Old Feb 24, 2010 | 05:19 PM
87Chev's Avatar
Default Need some advice!
hello i have a 1987 camaro that has a t5 tranny(i think it is, its a 5 speed) and a GM goodwrench 350 crate motor. i have heard that this tranny cant handle a 350. i want to start building the motor a little, it already has a high rise intake and a rebuilt 4 barrel. but i dont want to kill my tranny with too much power going to it. any advice helps! thanks!
Old Feb 24, 2010 | 06:54 PM
blackz87's Avatar
It is not the power of the 350 that destroys T-5 manuals but the repeated clucth drops & excessive power burn outs that do it. If you avoid this type of actions, you should be allright with mild 350 & t-5 as a daily driver.
Old Feb 25, 2010 | 12:39 PM
87Chev's Avatar
cool man thanks! but that is the last thing i have to worry about now. last night i lost all oil pressure. so i added three quarts and checked and it was fine. then i looked under the car to see if it was leaking and oh boy was it! it has a steady dribble coming from somewhere near the oil filter. im hoping the oil filter somehow got put on with 2 gaskets and it blew it out or the main seal blew out. either way those are easy fixes and are cheap. ever had that happen to you?
Old Feb 25, 2010 | 05:02 PM
blackz87's Avatar
I had a oil leak after a Dealer oil change and it was due to a defective filter.
Old Feb 26, 2010 | 03:12 AM
87Chev's Avatar
turns out the check oil light sensor blew out and it was leaking from it. simple fix that cost me 4 bucks!
Old Feb 26, 2010 | 08:59 AM
adam86107's Avatar
I recently had a similar situation. I got the oil changed and then about a month later i was under the car and noticed oil coming from the oil filter so I just tightend it down and called it good. A few weeks later (I hadn't been driving the car) I noticed it was still leaking, so I put an oil filter wrench on it and then take it for a spin, when I get back its just pissing everywhere. I do an emergency oil change (thinking the seal on the oil filter was bad) and when I removed the filter there was a big hole in the oil filter itself. Apparently when i put the oil filter wrench on it it squeezed it tight enough to make the hole bigger.
sohcnick
Mar 25, 2013 04:03 PM
mynameishank
Oct 8, 2009 06:23 AM
imtico
Nov 8, 2007 12:14 AM
1981camaroz28
Oct 23, 2007 05:44 PM
Harvester
Sep 9, 2007 05:55 AM
