need a kickdown cable for tranny.
Old Aug 9, 2009 | 08:38 PM
Mesosneaky's Avatar
Default need a kickdown cable for tranny.
Looking for a kick down cable to fit the 700r4 tranny and the aftermarket edelbrock carb. I was wondering if edelbrock had one for their carbs?
I looked on summit but couldnt find anything matching.
Old Aug 9, 2009 | 09:00 PM
Jr. Mechanic's Avatar
August 2009 ROTM
http://www.jegs.com/i/B%26amp%3BM/130/70242/10002/-1
Fitment has nothing to do with the carburetor so long as it is not set up for a Ford TV cable. It's pretty much standard between Chrysler and GM.
Old Aug 10, 2009 | 05:00 AM
Mesosneaky's Avatar
hmm i just dont see how it connects to the carb. I have the stock cable zip tide. So the tranny is a little off and shifts abit too early. So i was looking for one that just hooks on and needed no adjustments. Thanks for your search and information.
Old Aug 10, 2009 | 08:22 AM
djs383's Avatar
Thats a wonderful way to burn up your trans. The 700R4 and 4L60 are very sensitive to TV cable adjustment. Did you swap the carb out yourself or did it come that way? Either way you couldn't seriously think zip tie is the answer could you?
Buy a correct cable for your year trans. Edelbrock linkage is not going to be the same as the Qjet. However a few companies make a corrector plate for the TV cable. By the way, how are you routing your throttle cable? The linkage for that is not the same as stock.
There are plenty of articles on how to properly adjust the cable, but first get your linkages/corrector plates set up properly first.
Old Aug 10, 2009 | 03:40 PM
Mesosneaky's Avatar
ok thanks the throttle is connected with a bolt and nut to the top of the EB linkage seems pretty good. what corrector plate/linkage should i get with the EB performer intake and carb?
Old Aug 10, 2009 | 04:20 PM
Old Aug 10, 2009 | 06:36 PM
Mesosneaky's Avatar
Hey thanks camaro found what i needed on the second link.
This is what i need to get rid of my zip tie . Than I can adjust the cable correctly from there.
I should beable to find something like this at lowes or home depot right? Don't want to pay $6 plus shipping if I can get it for $3.
or better yet autozone should have one i pass by there ever day going and coming from work.
Old Aug 10, 2009 | 06:43 PM
microkid's Avatar
March 2011 ROTM
Technical User
lowes or home depot, no. a local parts store, possibly. i know pep boys sells edelbrock carbs, they might carry one of those parts
Old Aug 10, 2009 | 06:48 PM
Read over the first link too sneaky. Carb linkage geometry for the TV cable connection is important for having it in the right position during throttle travel.
Old Aug 10, 2009 | 07:01 PM
Mesosneaky's Avatar
Thumbs up
yes thanks for both the links. I skimmed through it twice now. Once I get the part I will read through it slowly until I get everything. Thanks
Hmm i dont ever remember seeing pep boys around here. Napa,Monro but no Peps hah. I'll try auto zone and let you guys know. I'll take a picture cuz they never know what im talking about lol.
