need help with wheel finish
Old Jul 25, 2009 | 11:00 AM
bd92rs's Avatar
Default need help with wheel finish
i finally picked up a set of factory wheels for my 92 RS they are straight true wheels with wery little curb rash but the finish on them is terible
can anyone give me some advice on howto refinish them
thanks
Old Jul 25, 2009 | 12:32 PM
Mine were getting bad like that too, the clearcoat was either coming off or the aluminum was corroding under it. My plan was to hit the wheels with paint stripper to remove the clear, then polish them. I sold the car before i got to it.
Old Jul 26, 2009 | 12:21 AM
Stix80's Avatar
meguiars makes some really good products to help with finishes but you might try some polishing or rubbing compound first
Old Jul 26, 2009 | 06:52 PM
ScottD's Avatar
The only way to clean up corrosion under clear coat is to rub off all the clear coat. Steel wool, green pads and WD40. A few cases of beer later you will be down to the base. Then spray it with a good clear again.
Some kind of light abrasive spray medium may work but you will need a media both and lots of gear to do that. Depending on the extent of the corrosion, you may want to have someone blast them for you.
Old Jul 26, 2009 | 09:11 PM
If you don't want to use paint stripper, I found out by accident that carb cleaner, 0000 steel wool, and elbow grease will cut through the clear coat. Actually, carb cleaner can ruin paint too (it's designed to cut engine varnish) so be careful where you use it.
If you want to go with a polished finish, try using Flitz. I'm really impressed with how that stuff shines raw aluminum, amongst other things..
Old Aug 7, 2009 | 08:09 AM
jrdnrdg's Avatar
what i did was use steel wool and elbow grease until the clear was off. then i started at somewhere around 250 grit to get the corrosion off and worked my way up to wet sanding with 1500 grit. i finished it off with some mothers aluminum polish and bandaids for every raw fingertip. i posted the before and after pics to kinda give you an idea on how it could look.
Attached Thumbnails need help with wheel finish-dsc_2376.jpg   need help with wheel finish-dsc_2544.jpg
69PaceCar
Sep 15, 2011 08:15 AM
metallica_mummert@yahoo.com
Sep 28, 2010 12:04 PM
mikes77camaro
Dec 30, 2008 09:29 AM
dp66ny
Nov 3, 2007 09:29 PM
