won't finish B4 deploy....storage???
Old Dec 24, 2008 | 08:47 AM
mikes77camaro's Avatar
Default won't finish B4 deploy....storage???
Well...facing the fact that I won't finish my car before I have to deploy again. I'm going to leave it on jack stands and the gas tank and lines are removed so I don't have to worry about gas. The motor's installed but has not been started. It dosen't even have oil in it yet...justassembly lube. All openings are taped, covered or plugged.
Have I missed anything? Anything else I need to do to protect my investment while I'm gone?
Appreciate any advice/suggestions.
**Oh ya...got the rear disk brakes installed. It went pretty smooth...I'll post some pics before I leave.
Old Dec 29, 2008 | 04:13 PM
tode5tool's Avatar
Default RE: won't finish B4 deploy....storage???
well... im facing the same delema.. im deploying soon also.. but my wife will be home to watch it.. im leaving evrything in so ill put some fuel stabilizer in it.. be shure theres more then 4 jack stands. wouldint want one to fail and the car be siting on one side for months. i know how that gos.. bent my swing arm last time. as the engine gos.. ide be scard of moister geting into the block.. since theres no oil in it.. i dont know if you would like to put anyoil in it but it might be good for it. other then that sounds like you got it coverd.
Old Dec 30, 2008 | 07:39 AM
Best of luck on your deployment...stay safe!
Ya...I don't know if it should be stored with or without oil. Anyoneout there know the right answer?
Old Dec 30, 2008 | 09:29 AM
andyracer125's Avatar
Store the car with freshoil not old oil.
69PaceCar
Sep 15, 2011 08:15 AM
metallica_mummert@yahoo.com
Sep 28, 2010 12:04 PM
bd92rs
Aug 7, 2009 08:09 AM
