need help with T5 trans disassembly
I'm disassembling my T5 5spd manual trans from my 88 V6. I've got almost everything torn down execpt for the 1-2 syncro assy which I can't remove from the output shaft. It seems I cant pull off either the hub just in front of it nor the gear at the rear. Do I need have a machine shop press it off?
RE: need help with T5 trans disassembly
5spd, camaro, chevy, disassebley, disassemble, disassembly, dissambly, dissasembly, dissembly, manual, output, repair, shaft, t5, trans
