Need help after bleeding rear disc brake.
Old Jul 24, 2022 | 04:49 PM
miche25's Avatar
Angry Need help after bleeding rear disc brake.
Camaro Z28 - 1984, After changing my right rear disc caliper, I bleed my right caliper only to eliminate all air bubbles.
However, when the engine is running, my brake pedal goes completely to the bottom of the floor.
When the engine is completely stopped, the pedal is hard and stays in the top. there is always liquid in the tank.
I spent a good amount of liquid already, approximately (10 ounces,= 300ml)
Can air bubbles transfer to the left rear caliper?
Why don't I have a brake?
Old Jul 24, 2022 | 05:06 PM
Start the furthest away from the master and bleed all four wheels. Did you run the master empty? If so you have air throughout the system.
Old Jul 24, 2022 | 05:11 PM
Old Jul 24, 2022 | 05:15 PM
Old Jul 11, 2023 | 05:19 PM
athiel82z28's Avatar
Default Soft Brake Pedal
I have an 82 z28 crossfire injection with 4 wheel disc brakes. My brake pedal pumps up good with the car off but when I start the car, the pedal is extremely soft. I can stop the car but the pedal about goes to the floor and I have to be sure to give myself plenty of braking distance.
Here’s some back story in what I’ve done…
I replaced the front brake pads, rotors and brake hoses.
I replaced the left rear brake caliper due to the bleed screw snapping off. I replaced the left rear pads as well.
I have NOT replaced the right rear caliper or pads yet because I wanted to figure out my brake pedal issue first. This bleeder came loose fine for me though.
I have bled the front and rear brakes multiple times and I’m not getting any air out at this time. I also bled the lines at the master cylinder just to be sure there wasn’t air trapped there. I never got air when cracking the lines open.
The car will come to a stop but the pedal is very soft and goes nearly to the floor in order to stop. I’m just lost as far as what to try or do next. I have already gone through a large bottle and 1/2 of another large bottle of brake fluid while bleeding them all.
I have bled the from in Jack stands and then the rear. I have bled the rear and then the front. I have bled all 4 in the proper order (RR, LR, RF, LF). Nothing seems to be helping. My brake light is on as well. Not sure if that matters or not though.
Any ideas, suggestions, etc are greatly appreciated. The car did sit for about 25 years inside before I recently got it running. I don’t believe the master cylinder was ever ran dry either.
winger
Mar 17, 2018 05:33 PM
9434V6
May 19, 2013 04:35 PM
jp 71 camaro
Nov 7, 2010 08:36 PM
washtubman
82-92 V8 Tech
Apr 6, 2010 08:10 PM
nebt3x
Feb 21, 2007 04:11 PM
