Need help 92 camaro rs 25th 3.1L
So my dad years ago rigged the fan to come on when you turn the car on he ran the power wire through fire wall and plugged it into the ignition fuse slot under the dash. I had hooked up the ground last night gen drove Home. After I parked for 5 mins car no longer has power to the dash or ignition or the gauges even the fue pumpl doesn’t come on. But the rear hatch opens stereo come on the buzz goes off until you turn key forward. And I have the vats bypassed with a resistor.
Well I had lost the set of original keys but have now found them for awile now. I have the leads of the resistor plugged in to the plastic connector off of the white and purple wires. Another thing is that when I bought the 15 pack of resistors the first one I tried worked so I wouldn’t know if it’s still giving the right ohms
H
Got home sat in car messed with resistor a little and it started started 3 more times then I put the fuse in my power wire that runs to my amp and back to square one but now with fuel pump. When it started my rpm gauge didn’t move but fuel tank one did I think it’s deff a problem with this vats. So being should I reinstall the original key ignition now that I have found the original keys
