Need help with 82 camaro
Old Nov 10, 2011 | 11:55 PM
ScottD's Avatar
Originally Posted by LadyKs27
it seems like it needs another gear. not sure if it has overdrive or not? im in bay shore on long island
Bay Shore.....ooooh....about 7 hours from me. 8*(
Is this an original tranny? My 82 has a NON overdrive Th350 in it....not original, not stock, not supposed to even fit with stock tail extension....gave me a huge run around for my first few weeks with the car assuming I had the original TH400.
Honestly, it sounds like you have the same combo I do...a tach thats a bit off and a transmission without overdrive.
Old Nov 11, 2011 | 07:31 AM
Did you mean 700R4? T400 was from earlier days. But, the 700R4 wasn't an option in 82. The only automatic trans offered was the 200C 3 speed, not even a T350 could be had. Right, she doesn't have overdrive, that's been a given from the beginning.
Old Nov 11, 2011 | 09:38 AM
ScottD's Avatar
Yeah, thats what I meant....but I was half in the bag last night and couldnt remember specifics....200C doesn't have overdrive? That explains the nasty 2.77 gears my car originally came with.....
Old Nov 12, 2011 | 10:16 AM
LadyKs27's Avatar
i have the original window sticker. it says that the car came with either a 4 speed manual tranny or 3 speed automatic. dosnt say anything about overdrive. do you think the tranny could still be slipping or does it just need a 4 speed?
Old Nov 12, 2011 | 10:39 AM
A 4 speed manual isn't an overdrive either. Both transmissions that were available with your car have a 1:1 final drive ratio. You need to hook up a known good tachometer to know for sure what your true engine rpm's are. Factory gauges can have a tendency of lying to you. And as I asked earlier, you also need to feel/listen to the trans as it's shifting. Are you definitely getting a 1-2-3 shift?
Old Nov 13, 2011 | 12:05 PM
LadyKs27's Avatar
i feel the tranny shifting its definetly going through all the gears. i just picked up a tach from pepboys going to hook it up soon. i will let you know what happens later on today. again, thanks for all the help
Old Nov 13, 2011 | 06:53 PM
LadyKs27's Avatar
i hooked up the aftermarket tach, the tach in the car was WAY off. thanks a lot to everyone who helped me out
Old Nov 13, 2011 | 08:16 PM
Any time. At least now you know what's what. Whether to try and replace/fix your original tach, or keep the aftermarket, is up to you. I don't trust the factory 3rd gen ones at all though.
Old Nov 14, 2011 | 07:22 AM
torque_is_good's Avatar
I hope other 3rd gen owners pay attention
don't ever trust the stock tach as they are terrible
to the OP, glad to see you took the advice
Old Mar 29, 2012 | 02:07 PM
  #20
camaroteen82's Avatar
It's good to know I swiped my tach from my dually before we sold it. but if I may ask for a favor. Could you by any chance take a picture of your starter solenoid with the wiring attached. i have the same car as you 82 pace car replica and I've dropped a 350 into it with the turbo 350. I never took the old engine out and didn't see what wire goes where and I can't get it turn over. I think a picture of yours would be more helpful then anything at the moment.
