Need help with 82 camaro
I recently bought the 82 Indy 500 pace car edition camaro. It has a 3 speed automatic tranny and I'm having problems with it. It shifts fine but when I'm in 3rd gear the rpms are too high so I cant do more than 50 mph without having high rpms. Not sure what is wrong. Any one know what might be wrong? Thanks
It might not be a problem at all, but possibly a previous owner could have installed lower gears in the rear. How many rpm's are you considering "too high"? I have 4:10 rear gears, and at 50 mph, the engine is a little over 2500 rpm's. If your engine is racing well beyond that, you may have a slipping transmission problem.
or it could be like the original tach whic was still in the car when i bought it. if even blipped the throttle it redlined and idled at 2500
I picked up another tach on line and it showed the idle correctly but at 65 mph it showed 4k rpm's with the 700r4 and 2.73:1's attach a timing light with tach and verify. THe probe wire should be long enough to hold out the window and view oh, you're not looking to time it so plug #7 is ok to use for this purpose |
I know way inaccurate tach issues is a pretty common thing with the later third gen's. Not surprisingly, my 91 read double of actual. Didn't know it was an issue way back in 82?
If i were to do 50mph the rpm gauge is reading close to 5000. Is there anyway to tell if the tranny is slipping before i bring it to a mechanic? It shifts fine just dosnt allow me to go very fast in 3rd gear.
(Post 583410)
I know not either. I'm simply sharing my experience and suggesting that the tach must be ruled out before panic ensues |
ok. thanks for the help
Originally Posted by LadyKs27
(Post 583554)
Where in NY are you? Im in the Syracuse area. If your close, Id be happy to take a look for you. |
it seems like it needs another gear. not sure if it has overdrive or not? im in bay shore on long island
1) Make sure you can feel the transmission shifting 1-2-3.
2) Make sure the rpm's your gauge is showing is accurate, by hooking up an aftermarket tach, or a tuning tach. 3) Assume your transmission is either not shifting into third, or it's slipping. 4) Get #'s 1 & 2 out of the way before assuming it's #3. |
