Need 3rd gen info
Old Mar 2, 2006 | 12:11 AM
Turbospud's Avatar
Default Need 3rd gen info
Hi folks, Im new to the forums.
Im working on a budget minded bracket racer. My plan consists of the following: V6 chassis, V8 springs, and a mildly built 454.
Im wondering if
A: the 454 and V6 are interchangable
B: if the RS front end bolts directly to the V6 body
C: will the rear end of the V6 hold up to the twist of a 454
Thank you, and have a nice day.
Old Mar 2, 2006 | 02:24 PM
HaloNick's Avatar
Default RE: Need 3rd gen info
To hopefully answer some questions as I know:
1. There may be some moving of pieces to make the new engine fit, but it should.
2. The RS came in a V6 or V8, so it should fit.
3. I would not recommend keeping that rear end.
I don't know a whole lot about body work, but hopefully this will help.
Old Mar 3, 2006 | 04:12 PM
You will need to do a lot of shuffling & shoe horning to get a big glock into your car, as it was not designed with a big block in mind. The stock V6 drivetrain will get crispified in short order by a good running big block, so you will need to beef up everything behind the engine. You may want to consider a big (383") small block V8 and save yourself some work.
Old Mar 4, 2006 | 12:26 AM
rashii12345's Avatar
Youll need to replace the v6 enginemounts with the v8 mounts, they should bolt to the same place.
Secondly I HIGHLY SUGGEST using subframr connectors so that the subframes wont bend out of whack.
RodneysPhoto
Mar 28, 2011 01:44 PM
camarogurl843
82-92 V6 Tech
Nov 4, 2010 02:44 PM
Skidoo03
Oct 18, 2010 06:39 PM
Homestar1217
Jun 27, 2009 08:37 PM
vinnyboombots
Apr 4, 2009 03:14 AM
