is my posi going bad?
Old Apr 3, 2007 | 12:16 AM
MadMikeZ28's Avatar
Default RE: is my posi going bad?
Maybe you should make sure you have a posi and identify what type it is first.
Old Apr 3, 2007 | 12:21 AM
350rs's Avatar
March 2008 ROTM
check for the G80 RPO code, thats for your limited slip.
Old Apr 3, 2007 | 12:40 AM
coprunr's Avatar
a mini spool is not designed for street use (no spool is) because it locks the axles to gether solid. there is no difference between the wheel speeds in turns. parking lot manuvers become a nightmare , and your front tires wear REALLY quick. they also handle funny with a spool. may as well weld the side gears together get the same effect for free.
Old Apr 3, 2007 | 05:57 PM
microkid's Avatar
March 2011 ROTM
Technical User
RPO G80, 10 bolt. ill check at napa on thursday to see if they have the rebuild. now how hard would it be to rebuild it? do i have to take out the axles and the ring gear, or can i do it all while its in there without having to shim and re-align it all?
Old Apr 3, 2007 | 11:49 PM
coprunr's Avatar
yeah , just remember which shim goes on which side. pull the wheels , pull the drums , pull the diff. cover , remove the cinch bolt , slide the pin out , push the axles in slightly and remove the "c"clips, slide the axles out , remove the diff, caps and roll the diff. out . i've never rebuilt aLSD only replaced. but instalation is the exact opposite of removal.
Old Apr 4, 2007 | 09:12 PM
microkid's Avatar
March 2011 ROTM
Technical User
hhmmmm, alright. thatll be another thing to go on my now $1500 parts list. sucks having to be in school, i wish i could work full time
Old Apr 5, 2007 | 01:37 AM
MadMikeZ28's Avatar
ORIGINAL: microkid
Stay in school and learn something! My mom offered to pay for a college education but I wanted to work full time and learn my trade. Some times I wish I did it the other way.
Old Apr 5, 2007 | 05:44 PM
microkid's Avatar
March 2011 ROTM
Technical User
i stopped at napa, about $700 for the kit to rebuild, but $350 for a whole new unit. im not that worried about it, as long as it still works like a posi off the line, im not concerned.
Old Apr 5, 2007 | 09:56 PM
microkid's Avatar
March 2011 ROTM
Technical User
i swapped the tires again today, and noticed its back to acting properly. i put all my weight on the lug nuts to tighten them, and it stayed locked. maybe it did it before because it was cold?
xeet2050
82-92 V8 Tech
Apr 22, 2009 04:39 PM
1985RS
May 16, 2007 09:52 AM
MadMikeZ28
Feb 2, 2007 06:32 PM
92camaroRS
Feb 2, 2007 06:24 PM
