My poor car has been bogging down
Old Oct 15, 2010 | 02:24 AM
akleeve's Avatar
Originally Posted by microkid
you would need to hook it up to a sofisticated diagnostic machine and have the grams per second read to make sure. thats going to cost about $60 minimum at a shop. just find one at a junkyard and test it out. if it corrects the issue, then youre golden. if not, you can start looking over the wiring harness or take it to a shop. before doing either, check the wiring where it goes over the belt. i have seen them come loose and have rubbed through the wires by touching the belt
will do, thanks for the help thus far micro. will post up results
Old Oct 16, 2010 | 06:08 PM
black89rs's Avatar
take your air cleaner off so you can see the maf and see if it is glowing. you will need to keep it hooked so u can run the car to look.
Old Oct 17, 2010 | 10:40 PM
akleeve's Avatar
So i grabbed a MAF from the junkyard (only 16 bucks, compared to a new one which is what, 150?)
swapped it out, seems the problem is fixed. need to drive it more to be sure. but it hasnt happened since the swap.
thanks for the help microkid!
Old Oct 18, 2010 | 06:40 PM
microkid's Avatar
March 2011 ROTM
Technical User
no problem. let us know if it comes back
hetrickw
Mar 21, 2012 01:55 PM
Hayden
Oct 13, 2011 08:20 PM
nybowtieboy
70-81 V8 Tech
Sep 9, 2008 01:30 PM
randolphdelpriore
May 27, 2008 01:36 AM
bawrestler
82-92 V8 Tech
Jan 29, 2008 06:05 PM
