MOTOR SWAP QUESTION
Old Nov 7, 2008 | 05:05 PM
9camaro1's Avatar
Default MOTOR SWAP QUESTION
Can i swap my tbi 305 for a 95' camaro lt1? and if so what do i need?
Old Nov 7, 2008 | 05:23 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: MOTOR SWAP QUESTION
fuel pump, ecm, lt1, wiring harness, a wiring guide, some patience and alot of time. probably an adapter for the trans im not sure. also change the optispark while on the engine before you swap it in if the engine has alot of miles on it.
Old Nov 7, 2008 | 05:24 PM
MadMikeZ28's Avatar
You can swap in what ever your heart desires. I have faith in you!
You will need the engine, computer, harness. The 95 computer if is automatic will be for a 4L60E and that is fully computer controled. So you either install a 4L60E with your swap or a manuals computer. Plus fuel pump. That should take care of the basic needs. There will always be those incidentals like fuel lines and hoses and such.
You also might want to check your area smog laws if any.
Old Nov 7, 2008 | 05:28 PM
Besides the complete engine and acessories, you will need the computer, wiring harness, and fuel system. If you plan to modify the engine, I suggest you get a 96/97 (OBDII)engine and computer as they are easier to tune, and have improved components. Otherwise, if you plan to remain stock, use a 93 model, wiring is a little simpler and a plain old 700R4 (4L60 not the 4L60e) transmission worksfine with it.
Old Nov 7, 2008 | 05:31 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
i know for a fact that the 95 computer is probably the worst one to use. my brother has a 95 Formula and its OBD1.5 or something. You need a special scanner to read it. Its an OBDII port but you cant read it with the OBDII scanner
gotmudnj
82-92 V8 Tech
Sep 24, 2009 10:22 AM
pimparsons
Jul 23, 2009 03:17 PM
rayray95
Feb 6, 2009 11:44 AM
Offerman92
82-92 V6 Tech
Jan 18, 2009 07:43 PM
Camroman250
Apr 30, 2006 12:17 PM
