More rear end questions
Old 02-23-2011, 03:27 PM
blackz87's Avatar
Originally Posted by djs383
He did mention that about richmond. He has a few brands in stock and said that I could change my mind between now and when they put something in. I don't mind noisey, as long as its not out of control. He mentioned a few other brands that he recommended over others. The price was within 10 bucks between brands. He said he liked richmonds products quality and durability over others. I have no plans of dragging the car as even with this set-up as I still believe the rear will be the weakest link. But with street tires I'll break those loose before any stress is seen by the rear. My next question will be what color driven gear to change out in the trans.
I never used Richmond gears, but knew people that had them. Like you thy said what is a little noise, but after a while they hated that whine.
Lets see if this helps out with 700R4 speedo gears...& 3:73 ratio
Drive 15T gray p/n 864260
Driven 44T dark grey p/n 9780470
Run this info by your gear sinstaller.
Old 02-24-2011, 08:17 AM
djs383's Avatar
Thanks for the help...
I Figured on the 44T driven gear needing to be replaced, but was hoping not to replace the drive grear . I currently have red which I believe is 17T. I need to sit down and see what the difference is between 15T/44T and say 17T/43T
sinfulrs
82-92 V6 Tech
12-05-2009 07:28 PM
mes5278
11-02-2009 10:44 AM
dustinb
11-30-2007 11:20 PM
Deezil13
12-12-2006 08:40 PM
camarokid1968ss
04-22-2006 01:38 AM
Quick Reply: More rear end questions
