Light troubles...
Old May 4, 2011 | 11:40 AM
305_camaro's Avatar
March 2012 Ride of the Month
Default Light troubles...
I recently took the dash out of my Camaro and when i installed it I hit the brakes and all of the dash lights and parking lights came on...can anyone answer this?
Old May 4, 2011 | 05:51 PM
carguy68ssrs's Avatar
Why did you take dash out? What else did you do to car? Did it have this problem before? A bad brake light bulb can do this. The element inside the bulb breaks and lands on the other element so when you energize brake circuit OR park light circuit the other also gets power. Happens alot on 1157 bulbs
microkid's Avatar
March 2011 ROTM
Technical User
sounds like theres a bad ground inside the dash somewhere. check them first
Old May 5, 2011 | 10:19 AM
305_camaro's Avatar
well i took the dash out because i had mice infest my car a few winters ago and it was already cracked when i bought the car. it just randomly showed up for some reason
Old May 5, 2011 | 10:20 AM
305_camaro's Avatar
oh and also the annoying beep comes on like when the car is shut off and the lights get turned on
Old May 5, 2011 | 06:05 PM
microkid's Avatar
March 2011 ROTM
Technical User
its supposed to do that. it alerts you that the lights are on and draining the battery. check around where you had it off an look for chewed wires
glue maker
May 3, 2010 11:04 PM
DacMan
Aug 9, 2009 06:25 AM
nick
82-92 V8 Tech
Sep 13, 2007 01:21 PM
blaclabel250
Aug 21, 2007 01:44 PM
