Just an idea, if it works
I live half a mile from the border and was thinking about putting a toggle switch on the ignition wire the runs from the fuse box to the key. So when i flip the switch off, the car can never be hotwired. Will this work or will I screw something up with the computer?
i just used a generic toggle switch from kragen. real simple to install. just find the constant to the ignition cut it and wire the toggle in between the two sections
