Just got a 1982 Berlinetta, need help
I just bought a beat up 1982 berlinetta with a broken gauges, broken stereo, leaking oil, extremely messed up interior, and not very quick. I want to bring it back to life and was wondering where to start. Any tips?
Better have got it cheap! haha. But Yes it is up to you. I'd do Body and chassis work first, then Motor, then interior fabrication. My general advice.
Which engine is in it?
from the sounds of it, i say swap in a junkyard motor, strip the interior, and lighten it as much as possible. if you want a nice car, sell it and buy one thats in better shape
if i were you, i would start with the engine. pull it out, and give it a fresh rebuild, from top to bottom. replace everything. this may get expensive, but by the time you are done you will have a fresh engine that will last a long time. while the engine is out, do all your body work and paint you engine compartment and the body. this will also be a good time to fix any other mechanical or electircal issues you have with the car.
