IROC Hood Replacement
Old Mar 6, 2007 | 01:26 AM
jdubs1813's Avatar
Default IROC Hood Replacement
I was thinking about replacing the hood on my 89 Camaro RS, the only thing is, when looking up prices, I found the IROC hoods to be sooo much cheaper. Will the IROC hood fit on an RS or will I have to go back to another RS hood?
Old Mar 6, 2007 | 01:30 AM
350rs's Avatar
March 2008 ROTM
Default RE: IROC Hood Replacement
fits just fine, look at my pic...
Old Mar 6, 2007 | 01:33 AM
jdubs1813's Avatar
Ok thx, never realized that you had RS with IROC hood.
Old Mar 6, 2007 | 02:32 AM
Tacos Z's Avatar
If you want fiberglass hoods, glasstek.com has some good stuff and theyre pretty reasonable.. Just a thought.
Old Mar 6, 2007 | 03:49 AM
MadMikeZ28's Avatar
If you get an iroc hood you also have to consider buying the louvres on it.
Old Mar 6, 2007 | 09:25 AM
350rs's Avatar
March 2008 ROTM
thats true. they fade, crack, break... mine is broken in half, but i still have the studs on the back so i drilled a hole through them and stuck a pin through it... it will work for now.
ZL1
Nov 2, 2013 04:10 PM
adam68
Jan 21, 2012 10:41 AM
Z28camaronut
Mar 16, 2011 11:38 AM
qmracer
Apr 6, 2008 10:29 PM
whoffman
82-92 V8 Tech
May 6, 2007 09:09 PM
