idles too fast
Old Jul 17, 2025 | 09:58 PM
eltrah83's Avatar
Default idles too fast
3rd gen 92 rally sport,3.1 engine idles at 3000 RPM when starting up cold ,After warming up to temp still idles fast between 1500 and 1750.Chat GPT suggested idle air control valve as most likely cause. Replaced idle air control valve. No change. Vacuum lines good. Idle starting at 3000 happened all at once, making me think it's a component and not a intake air leak. Fuel injected, not a throttle body .Any body had this happen and figured out the solution?
Old Jul 24, 2025 | 03:31 AM
have you had it scanned for codes?
Old Jul 24, 2025 | 06:38 PM
eltrah83's Avatar
Yes,it just showed check engine. It has been fixed. Intake leak. Runs normal now.
Old Jul 25, 2025 | 10:50 AM
kool, post a picture of your ride when you can.
89z
Jun 10, 2022 02:11 PM
87 camaro z28
Jan 3, 2021 02:01 PM
kblood
Nov 5, 2013 10:44 AM
dorkpunch
Aug 16, 2008 10:50 AM
72charger
Jul 17, 2007 05:58 PM
