idea
Old Mar 18, 2009 | 05:31 PM
Joker0907's Avatar
Default idea
I have a 1991 camaro rs 5 sp. and i plan on building it up. My idea is to get a 4 bolt main 350 block and build it up from that.
My ideas for a build were just the standard eagle rotating assembly kit, gm performance cast vortec heads with the eldebrock vortec intake a comp cams xtream energy Lift: .502''/.510'' Duration: 276°/282° cam, with a holly 670 cfm throttle body.
Now this is the first engine of my own that i will build so i may be way off on what im trying to build but what im looking for is around 10.1 compression and close to 400 hp. I want it to be a street/strip car i plan on doing some coilovers on the front and doing everything that i can to add to the handling performance because we do have a road coarse close to home i plan on taking it to. Does this set up sound good or am i way off?
Old Mar 18, 2009 | 06:52 PM
blackz87's Avatar
The 5sp is the weak link in your idea.
Old Mar 18, 2009 | 07:59 PM
Gordon24Camaro's Avatar
Richmond 6-speed should fix that.
Old Mar 18, 2009 | 08:24 PM
Joker0907's Avatar
how much does that 6 sp. run and how much fabbing does it take to put in? i def want to keep a manual in it. im not looking to be the fastest in town just to satisfy myself going down the track or on the course.
Old Mar 19, 2009 | 07:06 AM
blackz87's Avatar
Your dream idea needs to be refined, because the costs this project are going over the top. Unless you love that car, I would suggest buying a 6sp LS1 4th gen car. a lot of cheap ones out there.
Old Mar 19, 2009 | 03:48 PM
Joker0907's Avatar
3rd gen fan here... not much for the 4th gen nor the 2nd so this car is worth the money to me.
Old Mar 19, 2009 | 08:39 PM
Richmond 6-speed
http://store.summitracing.com/partde...16+4294908198+
T-56 from a 4th gen that also fits 3rd gens with very little fab work
http://store.summitracing.com/partde...198+4294839071
Old Mar 20, 2009 | 05:17 AM
Joker0907's Avatar
what about pulling a used transmission from a 4th gen camaro?
Old Mar 20, 2009 | 11:19 AM
350rs's Avatar
March 2008 ROTM
thats an option. But BE SURE to get one from a LT1. The LS is a different bolt pattern and will never work. Also, try and get anything you can for it in regards to linkage and what not. You can always try and sell the stuff you didnt use.
Old Mar 21, 2009 | 12:29 AM
91_Camaro_RS's Avatar
