How to use Stock gauges with vortec motor
Old Jun 23, 2013 | 08:22 PM
BlackBerlinetta's Avatar
Default How to use Stock gauges with vortec motor
I am wondering is it possible to use the stock gauges in my 86 berlinetta oil pressure,temp, and voltometer etc.. I have swapped in a 383 vortec motor and the guy helping me persuaded me to get an aftermarket cluster but I am cleaning up the interior and I would rather use the stock stuff. The wiring is there do I just need new sensors? Will they fit a vortec block?
Thanks for the help,
Blackberlinetta
Old Jun 23, 2013 | 09:34 PM
If you can transfer the sending units from the old engine to the new engine, the old gauges should work OK.
Old Jun 23, 2013 | 11:11 PM
sending units?
Old Jun 23, 2013 | 11:20 PM
Your stock gauges are electric. The oil gauge uses a pressure switch (sometimes referred to as a sending unit) in the block, and the temperature gauge uses a sending unit in the head. You can put your existing ones onto the vortec engine. The volt gauge is for the charging system and has nothing to do with what type of engine you have.
77nomad
Jan 2, 2012 08:24 PM
Murda99v6
Sep 12, 2010 12:59 AM
-Tommy-
Nov 16, 2009 07:41 PM
Black91Camaro
Sep 23, 2009 09:23 AM
