How to remove the fan switch connector
Old Aug 21, 2011 | 08:16 PM
microkid's Avatar
March 2011 ROTM
Technical User
quite a few. also is the cause a lot of the time for an engine that runs rich but has no check engine light. only way to find out is look at computer data
Old Aug 21, 2011 | 08:35 PM
Stevolwevol's Avatar
Which connection will cause the engine to run rich?
Old Aug 22, 2011 | 07:44 PM
microkid's Avatar
March 2011 ROTM
Technical User
the coolant temp sensor for the ecm. my car has a total of 3 temp sensors-gauge, ecm, cold start.
Old Aug 22, 2011 | 08:23 PM
I replaced the coolant temp sensor in my RS twice. I had trouble with my tranny (700r4) would go in and out of lock up as it was warming. I couldn't get a straight answer from anyone I talked to. I changed the temp sensor, and it quit. I figured since the temp sensor tells the ECM to start lock up after 130 ish degrees it could have been the sensor, and it was. So it controls closed loop, then I understand the thing about running rich.
Old Aug 23, 2011 | 09:37 AM
microkid's Avatar
March 2011 ROTM
Technical User
yup. if it still reads cold, then it will add more fuel to compensate for what it thinks should be denser air. i was also misinformed years ago and which sensor to remove to add a sending unit for a gauge. i was told to remove the cold start sensor. after that, the car wouldnt start below 30 degrees without eather
jlbonnie2000
Jan 15, 2014 06:54 PM
jlbonnie2000
Jan 13, 2014 06:31 PM
larryshon
Jul 28, 2009 02:20 PM
car5car
Mar 8, 2008 11:39 AM
dustinb
Oct 1, 2007 06:58 PM
