Hoods, Fenders, etc.
RE: Hoods, Fenders, etc.
That's good news ...mine needs pretty much a whole new front clip...so this is good news, I'm thinking of putting a different hood on too...since it needs that...well gotta go to work see ya
i personally like the Z28/IROC hoods a lot. Or a cowl induction if done right. 2 or 2 and a half inch lift at most in my opinion. Unless you need the clearance. There is also a daytona hood, which is kinda a combination of the two... very unique to say the least.
i like them, it makes you look you got something under the hood. plus its way better than that boring stock hood. that weighs a ton.
[IMG]local://upfiles/5168/AB1416F495924CE9B98E8B144415B9E9.jpg[/IMG]
ORIGINAL: Iowa87CamaroRS
P.S. I found out this is a 91...and totally screws up my name
The Daytona hoods, thier different. So you dont see a lot of them like cowl hoods. So I like them for that. But I like cowl hoods better.
there are a few different noses out there, so be careful when chosing. there is the 82-83 nose, 84-85 nose, 86-92 nose. there are 3 grille options of none, vent, and the iroc style. there are also 2 lips of the regular style and the rs with the faux brake ducts. you can pick whichever you like. most people like the iroc style insert with the regular or rs lip, and they tend to sell high.
You almost have it all right. The Z28 bumper coverwas from 82-84 then 85-92. The RS was an 87 -92 model but uses the same cover as the Z28. The fenders were the same until until 91-92 but that is only for some mounting holes for the G/E.
The grilles there were the 82-84 two piece. The the 85+ standard or standard with fog lights. or the iroc with foglights and camaro or a bowtie in the middle.
The ground efects had the ones for the 82-84 Z28, Then they got bigger in 85. The got the duct added to the front in 90 and then in the doors as well in 91-92 for all RS and Z28.
But they will all bolt on to what he has.
