Hood pin installation guide
Old Jun 22, 2007 | 11:00 PM
MIK3SREDROC's Avatar
Default Hood pin installation guide
Anyone that can find me a hood pin latch installation guide for a 87 IROC, or have installed one themselves and have any pointers I would greatly appreciate it. Thanks.
Old Jun 25, 2007 | 06:24 PM
zeus8807's Avatar
Default RE: Hood pin installation guide
i have them on my car, theres nothing real hard about installing them, as far as where to install them its up to you but your pretty limited on third gens to how far back go for the center of the front support, as to how far in, i dont rember exact but mine are roughly i think 4 inches in to the center of the hole. this is the only real thing you get to control without fabricating some mounted plates.
a few tips
#1 use a nail or nail set to prepunch the whole otherwise the drill bit will travel
#2 predrill it with a smaller drill bit
#3 get a drill guide(store bought or just a peice of metal with the right size hole in it that will allow you to drill the same angle on both sides) unless u have a steady hand and eye
#4 dont buy the $10 cheapes, they rust up real quick, spend the extra and get nice ones, i also clearcoated my plates.
#5 if your elimanting the hood latch like i did make sure itll pass inspection in you area most areas the only requirement is that the hood is held firmly in place but ive heard of guys failing for them too.
$6 dont bother with the locking ones(the ones without pins they just have the key) i cant even begin to tell you the horror storys i have heard about them.
i can give you pics but their not going to be any real help is very straight forward but if you just wanna know how they'll look i can help you there.
Old Jun 25, 2007 | 11:01 PM
Thank you very much, I did get the good set and I got a unibit to drill the whole it starts small and gets bigger the farther you go in. To make sure it doesn't travel i was told to put tape down, that really helps. Thank you for the help.
MusicMan
Nov 29, 2012 10:02 PM
Pontas
Apr 14, 2012 07:25 PM
nerfsmurf
Jan 26, 2011 04:18 AM
rwing7486
Oct 10, 2009 11:32 AM
evilkal
Jul 21, 2009 12:09 PM
