high heat issue...
Old 05-08-2008 | 09:25 AM
hshawn31's Avatar
Default RE: high heat issue...
i also noticed that the air intake temp. sensor has a wire that goes to the fan motor, would this sensor dying make the fan screw up?
Old 05-08-2008 | 10:40 PM
hshawn31's Avatar
turned on the A/C and the fan didnt kick on ( i didnt hear it anyway ) the temp. still rose to near 240
Old 05-08-2008 | 11:20 PM
Does the fan definitely go on at 240 degrees? If it does, it still could be that your gauge may be off. If it doesn't, check power at the fan with a meter, when the engine is up to temp. The fan itself could be the problem too.
Old 05-09-2008 | 10:39 PM
hshawn31's Avatar
i just noticed today that when you turn the key to "on" the coolant or temp. light doesnt come on...though i dont remember it ever coming on...i gues i'll start with a new motor, then hit all the sensors.
tjsmar
04-30-2011 01:25 PM
Chaotic94
01-10-2011 01:25 PM
gville4life
02-16-2010 08:33 PM
bezerker
12-18-2008 05:49 PM
72charger
09-16-2007 08:32 AM
Quick Reply: high heat issue...
