help with over heating problem
Old 04-07-2006, 06:40 AM
dmp7777777's Avatar
Default RE: help with over heating problem
i went through all that your going through and the man was right ,check to see if you still have an air dam thats probably your problem
Old 04-07-2006, 07:04 PM
SickSickSick's Avatar
One Thing He Didn't Mention Was If He Is Losing Water. A Small Crack In The Head Gasket Can Cause Overheating With Only Minimal Water Loss. One Sign That Might Be The Problem Would Be White Build Up On A Spark Plug Tip Where There Is None On Any Of The Others. Sick
Old 04-12-2006, 10:56 AM
89IROC Z's Avatar
I HAD AN OVERHEATING PROBLEM ON MY 89 CHECK THE HEADS MINE WAS MORE EVIDENT AT FIRST START UP WITH WHITE SMOKE BUT TO CONFIRM WICH YOU CAN DO WHAT SICK HAS SUGGESTED WITH THE PLUGS
Old 04-12-2006, 11:56 PM
tekanitrus's Avatar
Default don't forget!!
another ting to think about is the cooling fan relay, they go bad all the time.. If the one fan isn't working at all and the secondary kicks on only with the ac.. this might be the issue
mrsdeano
09-23-2010 10:35 AM
jproud27
09-16-2009 09:22 PM
71CamaroZ28
06-17-2009 09:39 AM
azmattaz06
06-11-2009 01:47 AM
My_94Z
03-31-2008 05:59 PM
Quick Reply: help with over heating problem
